Resets all PIM tunnel settings on an IPv4 module.
| ipv4 | Specifies the IPv4 module from which PIM is to be unconfigured. |
| tunnel | Specifies the tunnel which PIM is to be unconfigured. |
| tunnel_name | Specifies the tunnel name. |
If no VLAN is specified, the configuration is reset for all PIM interfaces.
If you unconfigure PIM globally using the unconfigure pim {ipv4|ipv6} command, you also unconfigure PIM-SSM, removing PIM-SSM range and SSM setting for PIM all interfaces. Static RP configuration is not removed in this case.
The following command resets all PIM settings on the tunnel accounting:
unconfigure pim tunnel accounting
This command was first available in ExtremeXOS 32.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
